1974 450 MKIII 4th & 5th gear selection problem!
Posted: Sun Oct 30, 2022 11:51 pm
I have been using the forum search to try and find some specific information about a developing intermittent problem that I am having with 3rd to 4th and 4th to 5th gear selection on "upward" changes. So far this fault is only occuring intermittently if the gear is held or accelerated in. Changing down a gear and then changing up again after accelerating is the only way to make the selection and it may take one, two or three attempts. When succesful, the gears engage smoothly and there are no nasty noises. I "feel" my way through a gear change, so can sense when the gear is fully engaged, before applying the power. Unlike some racers, who stamp their way up and down through a gearbox and wonder "Why?" they loose teeth, trash the clutch, or both!
There are no problems with downward changes in the gearbox, or upward changes between 1st, 2nd and 3rd gears.
Bearing in mind that the component parts in the gear cluster and gear change mechanism have now covered over 80K miles, I am suspecting that the shift forks width will have been worn.
They were built up with stellite rod and scraped, after the 5th gear on the output shaft, shed 5 teeth, back in 1977 and was replaced with a new gear. At the same time the dogs were undercut to 5°, if I remember correctly.
Motoscrubs_thread_"transmission+shimming"
Before I start dismantling the engine to see what is going on, does anybody have any theories as to "Why?" this inability to change up from 3rd to 4th and 5th gear may be happening? With the combustion side of things now nicely settled in, I'd prefer not to split the cases, but suspect delay might not be a wise option!
Some dimensional tolerances for the selector forks, the guides they run in on the gears and shimming tolerances for all associated components including end float of the individual shafts would be very much appreciated. I have both the Clymer and Haynes workshop manuals, along with a Clymer reprint of a narroiw case factory manual. But, none give any specific wear or running tolerances. Neither does Mick Walker's "restoration" paperback.
Thank you and good health, Bill
