DM450 MK3 ignition Fault
Posted: Sat Aug 13, 2022 8:18 pm
My 74 Ducati 450, which I have owned since 1974, has developed an ignition problem. This model has a CDI unit with Hall sensor as the ignition trigger and a 6-volt electrical system.
The bike starts reliably on first kick and then runs, but if it stalls, it will not restart until resting for some time, perhaps five minutes or much longer. My troubleshooting has this list of individual checks: battery, HT wire continuity, spark plug change, wire contact inspection, fuses, and swap with a new CDI unit from my spare parts. With the spark plug out of the engine and grounded, I have observed spark on the first engine turn over, but then no spark on subsequent turns. In other words, it has, I believe, replicated the starting failure described in the first sentence of this paragraph. The remainder of the electrical system seems to be functioning normally and the new battery is fully charged.
My last few rides of 30 miles or more this past week went fine and there was no evidence of trouble, in fact the bike ran great. What can be the problem? I am left with several possible causes: a bad Hall sensor, a bad ignition switch or connection, or a wire broken internally. (The running bike has had no stutter or cutting out as has happened with my BMW when the hall sensor went. And as you readers know, these bikes vibrate when started and shake connections all the while they’re running.) Further, the wiring diagram for this model is not in the Ducati Manual and the approximate diagrams for a CDI scheme which are on the internet from Mototrans and Electrex are general and may lack wire color indication.
Can some of you offer a diagnostic approach or possible cause? Thanks.
