What tail light for 69 WC 350 scrambler?
Posted: Thu Jan 07, 2021 9:07 pm
Hi guys. I'm finally getting my 69 WC 350 SCR ready for paint after 4 years or so
I recently came across (and bought) what I think is a correct rear fender from ebay. I have another fender on my bike that I'm going to continue to use for now,.... but I want to fix and paint this fender while I'm at it so I can swap it later to be more original.
-Now that I've been looking into it more.... I'm not too sure which taillight bracket and light assembly would likely be the "most correct" for my bike.
When I bought the bike it had no registration and the guy seemed pretty convinced it was likely a 69 so I went with that.
The frame has this serial number stamped into it: DM 350 03234, and the engine serial number is 07211.
The upper rear engine mounting holes in the fame were 8mm holes (if this helps).
I was thinking the rectangular (vs round), light with the single hole bracket bolted onto the frame would be most correct?
Would this look right?
Appreciate any suggestions.
thanks
Jeff
thanks
Jeff
