Which piston?
Posted: Tue Jul 14, 2020 7:06 am
1975 250 Desmo
I was looking to fix an oil leak from the cylinder head, thinking that the o-ring between the head and barrel had perished. There was also oil at the end of the exhaust pipe.
Right, so off with her head, so to speak.
The o-ring had indeed hardened, but I took off the barrel while I could, and found that the top piston ring had corroded with the barrel, creating a groove large enough to pass oil.
No problem, a rebore will fix it - except that this turns out to be a 239cm3 engine.
Am I right in believing the barrel can be bored to take a standard 74mm piston?
There are some pistons available for various 250 models, were they all the same, or are they model specific?
Appreciate any advice, thanks.
