Jim is so right about the fork tubes. I think the general rule is nicer the tube is as far as pitting and rust goes the more bent it will be. The more pitted and rusty they are the straighter they will be.
I straightened some as Jim described. It is not that difficult.
There are a few different designs of the damper valve that holds the ball bearings. The particular one that has some of them staked in is prone to failure. Leaving loose balls at the bottom of the legs. My forks from a 66 scrambler were like that.
Also check the parts for wear particularly the damper piston, if the tubes are bent the piston wears on one side from rubbing. Mine had to be machined down and sleeved.
Don't be afraid to get into it though, it's not that complicated.
Good luck
Aaron
