Page 1 of 2
450 Desmo rear hub - help!
Posted: Fri Oct 30, 2015 12:59 am
by Stratos23
Hello, from New Zealand!
Although i've been tinkering with old Ducati TWINS for years now, I'm new to this forum having finally got my hands on a beautiful 450 Silver Shotgun - a bike I've frothed over since I first saw one in my impressionable youth! It's very original but suffers from being put together by its previous owner from a box of parts - and so some things just aren't as they should be.
But today's issue is with the rear hub, which is the FOUR bearing version without the circlip in the cush-drive side. I've just installed sealed bearings, but suspect that the order and orientation of the various spacer bushes is out - and perhaps some are missing - because there is binding as I crank up the axle spindle nuts.
Does anyone have a clear exploded diagram of the four bearing hub? I have the exploded diagram of the earlier version from the original manual, but it's both hard to decipher and different to my hub, particularly on the right/sprocket side. I can turn up spacers if I have to, but first just want to know what it should look like to start with!
Thanks in advance, Greg
Re: 450 Desmo rear hub - help!
Posted: Sun Nov 01, 2015 8:53 am
by ducwiz
the arrangement of all the bits is visible in this drawing from the 450's spare parts catalog:
Parts 410, 295, 290 and 480 define whether the hub bearings and/or those in the sprocket carrier bind if the axle nut is tightened. The lengths of them are also given in the PC:
290: 9.5mm
295: 19.5mm
410: 6.0mm
480: 84.5mm
You can at first check both components on their own, i. e. using the axle and some pieces of steel tubing, then altogether mounted in the swing arm.
Posted: Mon Nov 02, 2015 2:43 am
by Stratos23
Brilliant - thanks Hans!
This is indeed the exploded diagram I was looking for. I really need a copy of the 450 parts catalogue - the previous owner apparently has one, but hasn't been able to track it down as yet.
Looking at the diagram, the arrangement/orientation of spacers on the sprocket side was not as it should be. That said, I mocked up the hub in the vice yesterday to approximate clearances and any side-loads on the bearings. Looks like I might have to turn one more up to get it right.
If it's not too much trouble, would you mind sending through a scan of the legend (part names/numbers) to this diagram - or if you know of a link where I can download an entire 450 parts catalogue?
Thanks again,
Greg
Posted: Mon Nov 02, 2015 7:51 pm
by ducwiz
Hi Greg,
the 450 catalog is an addendum to the 250/350 version. If you like, I can send it via email, it's roughly 1.5MB. You can send me your address in a PM.
Posted: Tue Nov 03, 2015 10:39 am
by Stratos23
Hello Hans - that's a very kind offer - THANKYOU!
I've just sent you a PM as suggested.
Kind Regards,
Greg
Posted: Wed Nov 04, 2015 2:22 am
by JimF
If Hans has only the 450 addendum let me know. I should have the wide case parts manual. Fellow member and good friend to all of us "ajleone" scanned a lot of manuals for us.
Posted: Mon May 20, 2019 5:50 pm
by themoudie
Please may I ask if either Hans, Greg or Jim are still posting on this forum?
Would any of them, or others, be so kind as to provide a scan/link of the 450 MKIII/DESMO 4 bearing rear hub layout and bearing specifications for this hub?
I have a '74 450 MKIII that I have owned since '76 and since dismantling the rear hub in 2005 the bits are 'muddled' and the original bearings removed!
I think that I have sorted out the spacers. 2 provide support for the bearings in the sprocket carrier and the plain spacer sits between the outer bearing and the swing arm, but I would like re-assurance please. I can post images of the 2 sprocket carrier types, if required.
I believe that the bearings would be 6004 RS (20x42x12)?
Thank you for your time and assistance.
Posted: Tue May 21, 2019 3:29 am
by JimF
Check your email, I think you should see four emails from me containing some PDFs unless either your or my email server rejected one or more owing to their size.
Posted: Tue May 21, 2019 7:02 am
by Bevel bob
Jim to the rescue yet again!, what a fantastic resource this forum is, all down to the people that inhabit it. And a real bonus, No bad tempered trolls!.Easily the most helpful bunch of bike freaks.
Posted: Tue May 21, 2019 9:34 am
by themoudie
Aye Jim,
Thank you for taking the trouble to email me the pdf's.
However, I had forgotten to amend my email address on the forum after changing my provider!
Please accept my apologies for the gaff and may I ask if it is possible to send the pdf's to my now correct email address?
My regards, Bill
