1971/72 125 Scrambler "Renata" (Rebirth)
Posted: Wed Jun 17, 2015 6:23 am
Hello, it's about time I introduce myself, James, and my new project bike, a 1971/72 125 Scrambler, the title/Bill of Sale says it's a 72(the advert and price tag said 71), and was told its actual displacement is 160, but I've found nothing on the bike so-far that has a date, or can confirm the displacement increase.
Engine stamp "DM125" "204XX" frame stamp at the head "DM125S*1253XX*"
What I've pieced together is that the 125's from this time period are uncommon, and somewhat different, the engine looks more like a narrow case in that the clutch cable enters the case.(Spanish made N-C)
I've measured the forks, they are 32.1mm(Edit: 32mm), I do have to confirm that measurement, the forks and shocks are Marzocchi, the tank it came with is incorrect, it was just sitting on it, it came from a Chaparral motorcycle from the similar time period, I have a replacement tank being shipped as I type this, I just hope its useable as there is some rust(some dents, 1 pin hole which was fixed), I'm still looking for both fenders(still looking) and side panels(found), plus a seat cover(in progress) or the whole seat.
I'm also not sure on what oil seal and gasket sets to get.
The rims are: mismatched so I believe one was damaged, I may mount alloy rims to reduce weight.
Front: PIETRO BERETTA & C BARANZATE(MILANO) W/ Nitto 2.75-19 (a replacement I believe)
Rear: RADAELLI SAS - MILANO W/Pirelli 3.50-18 Motocross
I have a few pictures... I know it may sound like an odd duck, but from my research and while taking it apart it does sound correct....
The brochure:
A side shot: (an XL70 in the background, my mom's old bike, will be restored next)
One of the better shots of the frame, just before I pulled the motor, the swing-arm is seized to the rod, heat did nothing, it will have to be cut out, I'm deciding if I want to convert to roller or go back with bronze bushings, but with grease fittings where there were none.(silly engineering)
The gauges: love them, with what I believe to be the correct mileage, the sprockets and chain(Regina) look relitivly new.
The motor:
The Carb: "Amal 375 20" which I deduced to mean a 20mm bore, not sure which gasket to get yet. (I may get a different carb, a Dell'Orto UB20BS was on an early 125 sport, or a Keihin CR if I can find one the right size)
A few shots for DewCatTea-Bob: The wiring is a mess, good thing I'm an electrician, I removed the whole wiring harness as one whole, still attached to the headlight as I found it(I've since separated the guts from the shell for re-chroming), which was far easier than expected for further dissection, the hard part so far has been trying to find the correct wiring diagram for it, every one I've seen is slightly different(still haven't found an accurate diagram).
Sadly the headlight was not complete, a few parts are missing, the switch, and something that attaches to the 2 bolts on the lower right, but what? The main switch at the top has more connections than the drawing(7 I believe).
The closest wiring diagram:
https://farm6.staticflickr.com/5468/188 ... 45_o_d.jpg
Also mentioned in books
P42, 47
https://books.google.ca/books?id=PJ8ht7 ... 22&f=false
P224, 225, 228
https://books.google.ca/books?id=JaXQtj ... 22&f=false
The brochure:
The motor:
P42, 47
P224, 225, 228
