Late model wide case exhausts
Posted: Thu Jan 22, 2015 1:22 pm
This thread was born out of a discussion about camshaft changes in my 1974 450 Mark 3, which can be seen here…http://www.motoscrubs.com/forum/viewtopic.php?f=3&t=1895
A question has arisen where my ’74 450 Mark 3 when fitted with the hotter 350 Green & White camshaft (rather than its factory stock mild 250 Scrambler White camshaft) and what I believe to be a stock Silentium exhaust, seems to bog down and in fact miss just north of about 4000 RPM.
This raised the following related points from the earlier thread…
These questions prompted me to do a bit of looking around. I hadn’t found it easy as I couldn’t seem to find a Parts Manual on line that includes the late model exhaust systems. After much hunting around, I finally found one covering up to the 1973 models and printed in 1974.
As I understand it, Sil Motor produced two structural versions the later Silentium long silencer. The first one was a two piece tube consisting of the primary baffle and a separate slice encapsulating a secondary baffle, joined together with the use of a ring clamp. You can see that here in this Ducati brochure for a front drum brake Desmo. :
I am uncertain of the IGM (Ispettorato Generale Motorizzazione) number on these as I don’t have one.
Later, Sil Motor produced for Ducati a slightly different construction silencer which was one piece although still with a separate primary and secondary baffle. See below my 74 450 Mark 3 which is labelled “Moto Ducati I.G.M 1984 S”. I have two of these, one of which was in its original sealed packaging with 40 year old company packing tape, so I am confident of its provenance.
Regarding the baffling (no pun intended!) question raised by Bob…if you look at these pages from the parts manuals, it’s not really clear to me what they are saying as to specific exhausts for different Ducati widecases. Note for instance 0615.84.105 is referred to as a Tromboncio rather than a Silenziatore. Any significance in that?
To add to the confusion….as I said, I have 2 Silentium Moto Ducati IGM 1984 S systems. Their secondary baffle is different. The old one that came with the 450 when I got it:
And the until recently unused one out of the factory packaging:
Can anyone throw any light on all this? It's primarily for interest, as I am most likely to continue running the 450 with a Conti replica style pipe anyway as the performance is much improved with it and the Green & White camshaft working in concert.
Kev
Kev: " One thing I have tried as an experiment was to put the Silentium back on with the G&W camshaft. Forget it. It won't run over 4000 RPM. "
DCT Bob: ____ I'm left to assume that the particular "Silentium" which you're meaning to refer-to is actually the shorter/stock Scrambler-style version, correct ?
If so, then there's something-else wrong if you actually literally meant that "it won't run over 4000 RPM",, so I rather assume that your must really mean that decent acceleration falls-off after that RPM.range, thus making that muffler/cam.model-combo to be pretty-much worthless.
Kev: No. I'm referring to the long one standard on the later Mark 3s (see picture below). I can't recall the IGM number off the top of my head. Before I put in the G&W camshaft, my original one had the rear baffle taken out, but it was starting to get a bit rattly and I had a new one around, so I installed it early last year. This still has all its baffles complete. It worked OK with the White camshaft although I'm sure it was restricting even that performance. With the G&W camshaft installed with the "new" Silentium, just over 4000RPM the bike will start missing (as in not firing). If I put the Conti style exhaust back on, no problem. I haven't tried the old Silentium with the final baffle removed.
DCT Bob____ I've unfortunately never had one of those newer Silentium-models to have ever examined. Do you know for-sure whether it's any more heavily baffled than the pre-1971 version ?
DCT Bob:____ That seems highly odd ! _ So I still think something-else has to be contributing to that strange result.
Is that not the same Silentium-model employed on the later 450M3D.models ?
In any case, it would be of keen interest to see what result would be found with that very-same muffler installed on the 450-DESMO !
And if & when it's found that the results of that test is-not the same and rather as normally expected, then you'd know for-sure to suspect that there's indeed another factor that's contributing to the over 4-grand strangeness.
. I am uncertain of the IGM (Ispettorato Generale Motorizzazione) number on these as I don’t have one.
Kev
