[quote= Ventodue ...
DewCatTea-Bob wrote: Monza Jr models (along with all pre-1968 Scrambler & M3 models) employ the 'green label' ign.coil which is intended for the magneto-type ign.system, while the 250 Monza models employ the 'red label' ign.coil that's intended for battery-powered type ign.systems.
" Do you know how they differ? "
____ Not entirely but, I believe that the green-coil has a less radical turns-ratio.
DewCatTea-Bob wrote:Anyhow, while it doesn't matter a great deal, the #1 terminal post is supposed to be connected to the ign.points, while the #15 terminal post is the one which is supposed to be fed by the power source (be it DC or AC).
Can you say a bit more on this, please?
Comparing the wiring diagrams for a) bikes with magneto-fired ignition b) bikes with battery-fired ignition, the coils seem to be connected differently. While the battery-fired models follow the 'classic' scheme (such as you describe), the magneto-fired system are shown with one terminal of the coil acting as a common terminal, taking power from the alternator and feeding it to the points. The other terminal on the coil goes to ground.
____
DARN, I sure hate-it when I fail to notice my-own posting short-falls !Thanks for bringing my oversight to light !
__ I should've better elaborated especially concerning the AC/magneto-type ign.coil circuit-arrangement.
In my quoted post-wording, where I stated "
should be connected to the ign.points,", I rather instead should've stated '
main-source of ground' !
(If I had gotten-around to reading my-own post again, I then probably would've noticed that wording-error and edited it to make more proper sense, as I often do.)
" But is this actually how these magneto-fired bikes were/are wired, do you know? "
____ Not-sure what you may actually mean by "this" exactly, but the magneto-type ign.circuit is set-up so that the points ground-out most-all AC.power-pulses until the particular power-pulse that's actually needed can be diverted from ground and left nowhere-else to go other than through the ign.coil (at the moment when the ign.points open).
And with that pointed-out, you ought-to now understand why the mag.type ign.coil-connections seem so odd (as compared to the "classic" ign.circuit).
