Horn Reconditioning
Posted: Thu Nov 01, 2012 4:36 pm
by gregwils
I had planned to separate my horn grill which is pretty rusty from the diaphragm to sand and rechrome, but that sucker doesn't want to let go. Is it possible to separate or does is need to go to some type of horn shop? Thanks.
Re: Horn Reconditioning
Posted: Fri Nov 02, 2012 1:31 am
by gregwils
I got the diaphragm separated from the cover. It was just a little stubborn after 45 years. It seems to have good continuity, so hope just test and rechrome the grill. Also for anyone interested, I found a write up on an old Bosch horn in an early Porsche, it's pretty close to the CEV.
http://forums.pelicanparts.com/porsche-911-technical-forum/469086-early-bosch-horn-restoration.html
Posted: Fri Nov 02, 2012 10:15 am
by Ventodue
Thanks for posting this. As the write-up says, horns are pretty simple and therefore easy to repair, but ...
I have never been able to find replacement aluminum rivets. And I don't like using self-tappers. If you manage to get some, please say where from - or even better, buy a bunch and I'll buy a few dozen from you!
Craig
Posted: Sat Nov 03, 2012 12:09 pm
by gregwils
Here is the photo I meant to share. The metal is solid despite deteriorating around the screw holes. The paper gaskets were incredibly thin and probably did more to hold moisture than offer any other protection.
PS - Craig - Did you read the Porsche thread, the author suggested aluminum rivets were available at Grainger. I'm not sure if those were the self-tapping type that you did not want.
Posted: Sat Nov 03, 2012 5:53 pm
by Ventodue
gregwils wrote:<snip> Craig - Did you read the Porsche thread, the author suggested aluminum rivets were available at Grainger.
Yep, Greg - thanks for that. I did see it, and subsequently found the rivets on the Grainger site. Have to see if they'll ship to me here in France ...
Craig
Posted: Sat Nov 03, 2012 9:00 pm
by gregwils
Let me know if they don't, I could order them and forward to you. My services are free, but can't promise prompt service.
Posted: Sun Nov 04, 2012 1:36 pm
by ajleone
Ok, dumb question - is the paper gasket required ? If so why and can just a piece of kraft/sjipping paper suffice as a replacement ? Thanks.
Tony
Posted: Sun Nov 04, 2012 4:12 pm
by Ventodue
gregwils wrote:Let me know if they don't, I could order them and forward to you. My services are free, but can't promise prompt service.
Thanks Greg. I'll give them a go and see what happens. The important thing is that at least I now know the rivets exist, and are (theoretically) available ...
Posted: Sun Nov 04, 2012 4:14 pm
by Ventodue
ajleone wrote:Ok, dumb question - is the paper gasket required ? If so why and can just a piece of kraft/sjipping paper suffice as a replacement ? Thanks.
Tony
I guess the gasket is there to stop the very thing it doesn't stop
. Water getting in and corroding the points.
Last time I fixed one, I just used a bit of gasket paper. Next time, I think I'll follow the line of the guy on the Porsche forum - get all modern and use silicone
