By: Jordan...
" There's a collection of cam data at ducatimeccanica.com "
____ Our w.site here also has such a list...
http://www.motoscrubs.com/Ducati_Tech/Duc_cams.htm ,
however it does have some stated errors !
Some-time I'll have to check-out that other w.site's list and look to see if it also includes any errors as well. ---> UPDATE-> I've since looked-over that cam.data-listing,, and not only is it's hand-written data rather messy to read, it's also filled with considerable misleading errors ! <-UPDATE <-
__ Back in the late '70s (when I became a tech-adviser for the DIOC), I compiled a complete list of all Ducati camshaft-data (sourced only from just actual D.factory released printed-data), which included cam/valve-lift figures.
I've always meant to post that complete list at this w.site but, so far I have yet to get-around to doing that task.
__ I also still have my collection of most-all 250/350/450 Duke-cams, (over 12 DIFFERENT cam-models !), the only std.cams missing from my collection is the 250GT-cam and the (real) 450Mk3-cam.
____ It seems we've been left to wonder exactly what the clearance-settings were set at when he -(44 Sebring) checked his valve-timing, so I'd have to guess that his figures were taken with the recommended valve-clearance settings for normal engine-running.
And if that's the case, then the cam's clearance-ramps were included (along-with the cam's 'lift'), which then unfairly exaggerates the timing-durations. _ That being so, there's certainly no way that his camshaft is a G&W.cam (which has at least 115-degrees of v.overlap) !
The 350/violet-cam however has only 50-degrees of overlap, which logically FITS within his (likely exaggerated) stated-specs (which happen to indicate 81-degrees of overlap).
Of-course that somewhat vague clue doesn't eliminate all other cam-model possibilities,, but I've been left to assume that his camshaft is likely a stock-350 cam, and his stated-figures rule-out all other 350-cams (other than the violet-cam).
