Horn Reconditioning
gregwils
Horn Reconditioning
I had planned to separate my horn grill which is pretty rusty from the diaphragm to sand and rechrome, but that sucker doesn't want to let go. Is it possible to separate or does is need to go to some type of horn shop? Thanks.
Greg W
1965 Ducati Monza
1966 Ducati Monza (Project)
1966 Ducati Monza Jr
1986 Porsche 911 Carrera
Pittsburgh, PA USA
1965 Ducati Monza
Pittsburgh, PA USA
gregwils
Re: Horn Reconditioning
I got the diaphragm separated from the cover. It was just a little stubborn after 45 years. It seems to have good continuity, so hope just test and rechrome the grill. Also for anyone interested, I found a write up on an old Bosch horn in an early Porsche, it's pretty close to the CEV. http://forums.pelicanparts.com/porsche-911-technical-forum/469086-early-bosch-horn-restoration.html
Greg W
1965 Ducati Monza
Pittsburgh, PA USA
1965 Ducati Monza
Pittsburgh, PA USA
Thanks for posting this. As the write-up says, horns are pretty simple and therefore easy to repair, but ...
I have never been able to find replacement aluminum rivets. And I don't like using self-tappers. If you manage to get some, please say where from - or even better, buy a bunch and I'll buy a few dozen from you!
Craig
Craig
gregwils
Here is the photo I meant to share. The metal is solid despite deteriorating around the screw holes. The paper gaskets were incredibly thin and probably did more to hold moisture than offer any other protection.
PS - Craig - Did you read the Porsche thread, the author suggested aluminum rivets were available at Grainger. I'm not sure if those were the self-tapping type that you did not want.
Greg W
1965 Ducati Monza
Pittsburgh, PA USA
1965 Ducati Monza
Pittsburgh, PA USA
gregwils wrote:<snip> Craig - Did you read the Porsche thread, the author suggested aluminum rivets were available at Grainger.
Yep, Greg - thanks for that. I did see it, and subsequently found the rivets on the Grainger site. Have to see if they'll ship to me here in France ...
Craig
gregwils
Let me know if they don't, I could order them and forward to you. My services are free, but can't promise prompt service.
Greg W
1965 Ducati Monza
Pittsburgh, PA USA
1965 Ducati Monza
Pittsburgh, PA USA
ajleone
Ok, dumb question - is the paper gasket required ? If so why and can just a piece of kraft/sjipping paper suffice as a replacement ? Thanks.
Tony
Tony
gregwils wrote:Let me know if they don't, I could order them and forward to you. My services are free, but can't promise prompt service.
Thanks Greg. I'll give them a go and see what happens. The important thing is that at least I now know the rivets exist, and are (theoretically) available ...
ajleone wrote:Ok, dumb question - is the paper gasket required ? If so why and can just a piece of kraft/sjipping paper suffice as a replacement ? Thanks.
Tony
I guess the gasket is there to stop the very thing it doesn't stop
Last time I fixed one, I just used a bit of gasket paper. Next time, I think I'll follow the line of the guy on the Porsche forum - get all modern and use silicone
