450 Desmo heads
Gboblebeef
450 Desmo heads
So I have been told that the 450 Desmo heads from the RT and the D road bike are different castings. Especially in the intake and exhaust ports. Can anyone shed some factual light on this?
Cheers, Gary G
Gboblebeef
Gboblebeef
Differing 450 Desmo-head Castings ?
" So I have been told that the 450 Desmo heads from the RT and the D road bike are different castings. "
____ I've had both types, and while the two different 450D-heads are clearly MACHINED differently, I don't recall any clues indicating that they're different "castings" as well.
" Especially in the intake and exhaust ports. "
____ I think that those two cyl.heads' intake-port/manifold-mouth mounting may look slightly different, but I don't recall ever noticing anything significantly different about their ex.ports, which could indicate differing castings.
" Can anyone shed some factual light on this? "
____ If there is indeed any such claimed differences, then I'd bet that fellow-member Eldert can confirm so.
PhilA
Re: 450 Desmo heads
The R/T has the decompressor, the road bikes don't. I suspect the R/T head is a modified normal Desmo item rather than a different casting.
Re: 450 Desmo heads
I had been told that the R/T had a 38mm intake valve and the road model a 40mm, can't confirm that from my own experience though.
Gboblebeef
Re: 450 Desmo heads
Yes the RT has a decompression device, not a lever like on the springer, but that is down to machining. I suspect the 38mm vs 40mm valve is machining too, but thus the original question.
Cheers, Gary G
Gboblebeef
Gboblebeef
Desmo-valves
By: wcorey...
" I had been told that the R/T had a 38mm intake valve and the road model a 40mm, "
____ All std.production DESMOs have the same 40 (& 36mm) intake (& exhaust) valve sizes.
I've never seen a 38mm DESMO-valve !
Re: 450 Desmo heads
the Mark III 450 Desmo head and the 450 RT Desmo head look the same to me .
they have the same 40 / 36 mm valves to
the compession release is the only thing that sets them apart
Users browsing this forum: No registered users and 107 guests
