cam drive gears
bodge
cam drive gears
Postby bodge » Fri Aug 02, 2024 9:51 am
just a quick one can anyone tell me if 175 upper bevel drive gears are the same as 250 on the narrowcase engine,thats the gear on the end of the long shaft and the camshaft gear
Re: cam drive gears
Postby Duccout » Fri Aug 02, 2024 11:30 am
I don't think so, the part numbers are different.
bodge
Re: cam drive gears
Postby bodge » Fri Aug 02, 2024 3:28 pm
bugger bit the bullet and bought the parts before you i saw your reply,something else for the box of bits ive bought in error :lol:
bodge
Re: cam drive gears
Postby bodge » Mon Aug 26, 2024 10:35 am
looking for upper bevel shafts/cam gears getting a bit confused.what length should a 250 shaft be ? seems there usualy measured from the underside of the gear to the end .
im also seeing 2 types of shaft 1 with a continuous thicker shaft and one waisted type where the majority of the centre section is narrower,is this how you tell 250 from 175 if not length or is the thicker shaft a widecase or performance model i.e mach 1 thing.
i finally got hold of a 4 speed parts book from ducati mecanica site and that shows a waisted type for a 250 but dont know how accurate that is.
Re: cam drive gears
Postby Duccout » Mon Aug 26, 2024 4:51 pm
I THINK the shafts that are waisted are narrow-case and the thicker shafts are wide-case, but I may be wrong.
Re: cam drive gears
Postby LaceyDucati » Tue Aug 27, 2024 7:27 am
250 narrowcase top bevels are the same as the 175 in length (both have the same stroke). Thin shafts are narrowcase and thick ones Widecase as George said. 250 wide and 350 narrow are functionally the same, but different shaft diameters (but can be interchanged).
Nigel
Users browsing this forum: No registered users and 287 guests
