Bridge Rectifier
Re: Bridge Rectifier
Postby ducwiz » Thu Jul 29, 2021 5:17 pm
Applause ;)
Please, report if voltage regulating and battery charging work well.
frankfast
Postby frankfast » Fri Jul 30, 2021 10:33 am
Throughout the course of this discussion there is no mention of the red wire from the alternator. With the bridge rectifier currently on the bike, the red wire is not used. The schematic of the 6 volt system shown previously shows the red wire connected to the same terminal on the regulator that is connected to the battery. I'm assuming that with the 12 volt Chinese R/R that the red wire from the alternator is abandoned. Is that correct?
Postby ducwiz » Fri Jul 30, 2021 9:47 pm
Again you got it right! Leave the red wire from the alternator unused, and keep the Faston terminal safely away from any conductive bike part, by insulating it properly a,nd fixating it with a ty-wrap.
Postby Jordan » Fri Jul 30, 2021 10:39 pm
frankfast wrote:Throughout the course of this discussion there is no mention of the red wire from the alternator.
Not correct - please re-read the thread.
Hans has the best understanding so it's safe to go with his advices.
frankfast
Postby frankfast » Sat Jul 31, 2021 11:23 am
You are correct. My apology. Ducwiz has been precise in his instruction as has all who have contributed to this thread. I will never be proficient in the workings of electrical systems but, at least, I now know which wire is connected to which terminal and changing to 12 volt should be advantageous. Thank you all.
frankfast
Postby frankfast » Sun Aug 15, 2021 10:53 am
ducwiz wrote:Hi,
1 x black wire = regulator control input, +12V from ignition switch
Since I no longer have an ignition switch but rather a simple toggle switch to supply power to the coil from the battery, does the black wire from the Chinese 12 volt substitute power to the coil or do both the black wire and existing power from the battery (via toggle) connect together to the positive terminal of the coil? Not sure what exactly the function of the black wire is.
Postby ducwiz » Sun Aug 15, 2021 1:16 pm
http://www.motoscrubs.com/forum/viewtopic.php?f=3&t=3382&start=10#p26690
No! It is the "sense" input of the R-R, same as the "marrone" terminal on the original Ducati 6V R-R. You will connect it to the coil sided terminal of your toggle switch.
frankfast
Postby frankfast » Sun Aug 15, 2021 8:24 pm
Thank you again Hans. I think that does it but I've said that before.Waiting on my 12 volt battery.
Users browsing this forum: No registered users and 85 guests
