66 Monza handle bar switch
Davescycles72
Wiring diagram shows a 4 wire light/horn switch, this has 7? And the colors are not correct. Is this the wrong switch,for this bike?
Davescycles72
Re: 66 Monza handle bar switch
Wiring diagram shows the handlebar switch is for horn and high/low beam.
But the photo shows a switch with more functions so more wires.
No surprise, as these type of switch are not high durability components and often burn out in use, and replaced with whatever.
That's why it's good to add relays if you can.
Davescycles72
This switch duplicates the function of the headlight key switch, and was confusing. I have a four wire horn dip switch I will use. Just goes to show when you buy a basket case bike,all is not what it seems. Thanks Jordan
Blaine.Hale
My 67 Monza 250 has the usual Aprilia CEV switch unit with high/low beam, horn and a 6v wire. Bolts directly to the stock clutch lever housing. https://i.ebayimg.com/images/g/ywMAAOSw ... s-l300.jpg
Users browsing this forum: No registered users and 118 guests
