Bottom bevel bearings.
Buster
Re: Bottom bevel bearings.
If the cases are heated and the bearings are kept in the freezer overnight they should drop in.
jbcollier
Re: crank shimming
You can't shim the crank "tight". If you do, it just pushes the crank out of alignment. You just shim to take out the play, that's it.
Users browsing this forum: Majestic-12 [Bot] and 171 guests
