any experience with motorcycle lift tables?
cooperplace
Postby cooperplace » Sat Apr 04, 2015 5:30 am
does anyone have any recommendations for these? They can be had on Ebay from around $400 + freight. I mean the type that has a ramp, a table, a clamp for the front wheel, and has a foot-operated jack.
This is just for home use, not commercial. Obviously a lock is needed so it's not held up by the hydraulics. Any reviews from users would be welcomed.
thanks
be nice, I'm not very bright.
Re: any experience with motorcycle lift tables?
Postby Ventodue » Sat Apr 04, 2015 7:40 am
Wouldn't work without one. Advice? Well, they're pretty simple affairs ;) , but:
1. Buy something sturdy (obvious, but probably worth saying :)). But not too heavy, either - chances are, you will have to move it around ocassionally.
2. My own uses a hydraulic jack. Don't get one which has the jack 'built in' - if the jack fails, then the table is US.
3. On mine, the table locks in within simple steel pins. Simple, but works (and I like 'simple').
4. Worth getting one with a removeable floor section beneath the rear wheel.
HTH
Craig
machten
Postby machten » Sat Apr 04, 2015 11:09 am
Or just make your own for sub AU$100 including removable back wheel floor. You need a portable ramp anyway.
Kev
cooperplace
Postby cooperplace » Sun Apr 05, 2015 9:10 am
Thanks, I've got one like that, I made it out of timber for about $75, and it's OK but it's a 2-person job to get a bike on or off. With a hydraulic unit, I could lower it, wheel a bike on to it, clamp the front wheel in, and raise it, all by myself, which is what I want to do.
Users browsing this forum: No registered users and 156 guests
