setting timing on 250?
amartina75
Re: setting timing on 250?
Postby amartina75 » Thu Jul 17, 2014 10:06 pm
cooperplace wrote:The problem is, with the dial gauge probe in the cylinder, the piston comes up, hits the probe, and locks the engine solid. Reasonably large amounts of force, thru the kick-starter, won't move it. So I don't know if it's at TDC.
you will find it very difficult to get to exactly TDC by using the kick starter. put the bike in high gear, rotate the rear wheel or depending on how you have your degree wheel bolted to the crank use a wrench on the bolt and rotate the crank directly.
1966 250 Scrambler
Postby DewCatTea-Bob » Fri Jul 18, 2014 2:58 am
[quote= amartina75 ...
" you will find it very difficult to get to exactly TDC by using the kick starter. "
____ Indeed so ! _ Next to impossible even.
" put the bike in high gear, rotate the rear wheel "
____ There's certainly a better chance that way, but the trans has too much slop to make that method very easy to adjust for dialing-in to TDC !
" depending on how you have your degree wheel bolted to the crank
use a wrench on the bolt and rotate the crank directly. "
____ That's still better yet, however an ordinary "wrench" doesn't hold the bolt-head tightly enough, so rather use a 'vice-grip' to grab & hold the bolt. _ Or best-of-all, if ya have the degree-wheel secured adequately, then simply use IT to turn & adjust the crankshaft & TDC.position !
__ Here's a link to a related thread...
viewtopic.php?f=3&t=383
And here's a link to an included post with quite useful degree-wheel mounting info...
viewtopic.php?f=3&t=383&p=2602&#p2584
Users browsing this forum: No registered users and 95 guests
